Brief Description: Began Trimming the Baffling for the Plenum
I screwed in the aft baffle parts to tighten them up. The plenum was placed in place and the top was traced around the inside of the baffles. The left aft corner of the plenum will have to be modified because it is too short. The left front baffle was taken off and clamped to the portable table. The cutoff wheel in the Dremel was used to trim off the excess on the baffle part. The edge was cleaned up on the Scotchbrite wheel.
The plenum set in the baffling
The left aft corner of the plenum is too short in the baffling
