Brief Description: Baffle Back Left Side #5/Cowl Inlets Sanded
The baffling back left side, #5, was drilled to the bottom corner of the left rear side baffle. The oil cooler will be located on this piece.
I used the die grinder to clean up the inside edges of the cowl inlets. The two cowl inlet holes were sanded to the proper radius of the rings. The air filter inlet was also cleaned up, but the ring is larger than the inlet, so the inlet needs to be enlarged.
The left rear baffle where the oil cooler will be located
