Baker's RV-6
Date:  3-1-2011
Number of Hours:  3.00
Brief Description:  Started to Install Baffling
I laid out all of the baffling pieces from Van's kit. I installed the two pieces on each side of the engine. Areas of the baffling around the cylinder heads had to be filed out in order to lie flat. I modified the areas on the Scotchbrite wheel and then the die grinder. I did the same thing with the bolt reinforcements and then the side pieces were bolted to the case.
The left pieces and reinforcements
The left side
The left side
The right side
The right side
