Baker's RV-6
Date:  2-10-2011
Number of Hours:  0.50
Brief Description:  Cabin Heat Control/Mixture Cable Hole in Firewall
I measured the position of the mixture cable so that the firewall grommet could be used, which requires a 1 1/8" hole. The hose that connected the left and right exhaust pipes was removed for better access to the firewall for drilling and installing the grommet. A pilot hole was drilled in the firewall.
The cabin heat control attached to the heater box
Proposed position of the firewall grommet
Drilled pilot hole for the mixture cable
