Brief Description: Laid out Reinforcements for Air Filter
Joe Walker gave me some PVC pipe to use for setting the distance for simulating the prop. He traced two circles on .040 material to be used for reinforcing the air filter which will be sandwiched between fiberglass pieces of the air box. Joe also marked the area to be cut out of the air box.
The reinforcements that will be placed between the fiberglass and air filter
