Brief Description: Finished Drilling Firewall Flange/Trimmed Top Skin
I finished drilling holes thru the rest of the firewall flange. I kept dipping the bit in cutting oil before each new hole to help the bit get thru the stainless. The top skin was removed to debur the holes on the skin and the firewall flange. The top skin was clecoed back in place. The front overhung the firewall flange by about 1/4''. The line was marked and the top skin removed. The top skin was clamped to the work bench and the Dremel cutoff disk was used to cut off the excess.
