Baker's RV-6
Date:  11-18-2013
Number of Hours:  1.50
Brief Description:  Helped Install Flap Control Rods and Flaps
Walt Halloran helped install the flap control rods onto each flap. The hard part was getting a nut and washer on the backside of the bracket and screw them onto the rod end bracket. AN364-428 nuts were used on the back. We then installed the flaps on the aircraft. The hinge pins had BoeLube rubbed on them to make them easier to insert thru the hinges.
The left flap installed
The right flap
The right flap
The control rod on the right flap
