Brief Description: Trimmed Right Wing Spar Web for Trim Cable
Jeff helped me pull the right wing out. I trimmed the spar web to remove the interference of the trim cable. The Dremel cut-off wheel was used, along with the Unibit.
The right wing inserted after the trimming
The fuel tank bracket is lining up with the fuselage bracket
The right spar web after trimming for the trim cable
