Brief Description: Marked Right Spar for Trimming for Trim Cable
Reference lines were drawn on the front of the spar web for trimming around the trim cable. The cut-off wheel in the Dremel was used to cut one line in the web. A pilot hole was drilled and then enlarged for the cable. The wing has to be pulled out in order to properly trim the spar web.
