Baker's RV-6
Date:  10-2-2013
Brief Description:  Used Tie-Wraps to Tie Wire Loom to Ribs
I finished drilling holes for the tie-wraps in the ribs. Tie-wraps were installed in the first three ribs, the access hole rib, and the last two ribs. The wire loom and wires were tied to the ribs in each wing.
Update: The tie-wraps in the second and third ribs caused a problem later when I attempted to run another wire thru the wire loom. These should not have been used.
The wire loom on the inboard right wing
