Brief Description: Reinstalled Left Fuel Tank/Visitors
When the left fuel tank was removed the day before, some screws could not be unscrewed back out thru the holes in the fuel tank. The screws were removed after the tank had been removed. Two screws broke off and the shanks had to be drilled out. Tinnerman washers will have to be used to provide the proper material for screws to be screwed into.
Visitors: Dale and Joanie Holmes Dale brought me a tube of Proseal to use as a replacement for the rubber gaskt on the fuel sending units.
