Brief Description: Moved Fairing Nutplate on Wing/Filled Hole
The aft hole in the left wing fairing was drilled too close to the end of the wing. The nutplate riveted to the wing ended up rubbing on the flap. The nutplate was drilled out and new holes were drilled moving the nutplate forward. A new hole was drilled in the fairing. The bad hole in the fairing was sanded and then had a layer of fiberglass laid under it and glued. The hole then had a small amount of resin and flox placed in it.
