Fittings were added to the cut down tubes off the pitot tube. The tube ends were flared and the quick disconnect plugs were attached to the fittings. The shorter aluminum tube on the pitot tube is the pitot line and the longer one the static and AOA line. Per the SafeAir Static System instructions, the green tubing will be used for all of the pitot tubing and the blue tubing will be used for the static/AOA tubing into the instrument panel. The tubing was run thru the grommets in the ribs and then attached to the pitot tube fittings.
The pitot tube with the fittings and tubing attached
