Brief Description: Removed Left Fuel Tank/Pitot Tube Plumbing
The left fuel tank was removed from the wing. The pitot tube plumbing was pulled out of the wing. The pitot heat controller was put into the left wing access panel to see how it could be positioned.
Left wing after the fuel tank was removed
The pitot heat controller held in place against the access panel
