Brief Description: Trimmed Aft End of Left Wing Tip
The left wing tip was about 1/4" too long, compared to the aileron's position. With the aileron on the wing, the correct line on the wing tip was marked with tape. A cut-off wheel in the Dremel was used to trim off the excess. Cuts had to be made on each side.
