Brief Description: Marked Trailing Edge of Left Wing Tip for Trimming
With the left wing tip screwed to the wing and the aileron installed, the wing tip was approximately 1/4'' too long. It also did not lie parallel to the wing from the center aft. The aft outboard corner of the tip was almost an inch higher than the wing. The wing tip would have to be modified. The tip was marked with tape for trimming off the excess length.
