Brief Description: Made Holes in Fuselage for Flap Control Rods
With the bolts in the flap brackets, lines were determined thru the fuselage for the flap control rods. A #30 hole was drilled as a starting part and then the Dremel was used to enlarge the holes. The rods were attached to the flap actuator and then run thru the holes. The holes were enlarged as necessary to allow the flap control rods to move freely as the flaps moved up and down.
The left side of the fuselage and the initial hole
The left side of the fuselage with the flap control rod
The initial hole in the right side of the fuselage
