Brief Description: Riveted Rib to Rt Wing Tip/Trimmed Tip
The rib was riveted inside the wing tip. Measurements were made as to the location of the wing spar interference with the wing tip and the tip was marked. The two areas were trimmed away so that the wing tip will nest into the wing properly.
