Baker's RV-6
Date:  2-20-2013
Number of Hours:  1.00
Brief Description:  Worked on Trimming Inboard Edge of Left Flap
The top side of the left side was marked for trimming so that the flap would lie next to the fuselage with about a 1/4" gap. The cut-off wheel in the die grinder was used to trim the skin. The flap was trimmed a few times with the cut lines cleaned up and the flap held in place to check the fit. After the flap was trimmed to the correct shape, the lower inboard corner of the flap had a joggle put into it, so that it would lie against the fuselage properly.
The timming marks on the flap
Checking the fit of the flap
The lower corner bent around the fuselage
