Baker's RV-6
Date:  2-9-2013
Number of Hours:  4.50
Brief Description:  Primed/Bolted Wing Attach Brackets
The components of the wing attach brackets were cleaned up and primed. With Mary's help, both brackets were bolted and torqued to the fuselage. The lowest bolt hole in each bracket did not have a screw installed in it because the fuselage had to be countersunk with a #10 bit, which I did not have.
The attach brackets
The attach brackets
The left bracket inside the cockpit
The right bracket inside the cockpit
