I drilled a 1/4'' hole thru the upper left corner of the F-605 bulkhead for the static tube. Jeff brought out the wing tips that he had basically completed. I checked the fitting of the nav lights in each wing. I sanded the upper side of the openings so that the lights fit better. This was done by sanding, then screwing the nav lights in place, check the fit and repeat.
