Brief Description: Drilled NACA Vents/Fiberglassed Nav Lt Extensions
Drilled two more #40 holes in each NACA vent and drilled them to the fuselage. All holes were deburred and then dimpled in the skin. Dimpled the holes in the vents with the deburring tool. Worked with Jeff and fiberglassed the nav light extensions into the wingtips. I sanded the right wingtip area and the extension, then cleaned the areas with acetone. After watching Jeff glass in the first wing tip, I glassed in the second wing tip and laid in flox.
