Brief Description: Prosealed Left Fuel Tank Cover Plate
Cleaned left tank cover plate, fuel sender, and inboard rib with MEK. Spread EZ Fuel Lube on both sides of cork gasket. Placed gasket on tank cover plate and positioned in place on rib. Spread anti-seize on screws and inserted in cover plate. Spread EZ Fuel Lube on both sides of rubber gasket. Placed gasket on sending unit and positioned in place on cover plate. Spread anti-seize on screws and inserted in sending unit. Mixed up almost 10 grams of Proseal. Spread Proseal around heads of all screws. Tightened all screws. Spread Proseal around cover plate edge. Left tank is completed!
