Brief Description: Prosealed Rivet Heads on Right Baffle
Wiped down rivet heads on left baffle and left inboard rib with MEK. Mixed 30 grams of Proseal and applied to rivet heads. Wiped down rivet heads on one side of right baffle with MEK. Placed a lot of Proseal in the outboard corner on right tank. Cleaned out Proseal from some screw holes with rags and MEK.
