Brief Description: Prosealed Left Inboard Rib/Check Left Tank
Took board clamps off right tank. Saw that both inboard and outboard bottom corners of baffle had not had enough Proseal and so had holes and will need to be filled in.
Tightened fuel vent line to fitting in left fuel tank. Had to bend vent line in two bays because vent line was a little too long. Double-checked all ribs and stiffeners in left tank for voids. Mixed ten grams of Proseal and covered voids and rivet heads on inboard end rib. Riveted last rivet next to the fuel vent line fitting using rivet gun and pointed bucking bar.
