Brief Description: Finish Riveting Ribs 3 & 4-Right Tank
Placed tank in the cradle, used Keith Woodell's swivel rivet set to rivet bottom side of ribs 3 & 4. Riveted the two doublers into place at the LE rivet position on each rib. Also need to rehit next three rivets to try to set the heads down a little better.
Ribs 3 & 4 Prior to Riveting Bottom Sides
Painter's Tape Strips Ready to be Placed on Rivet Heads
