Brief Description: Rivet Misc. Stuff on Outboard Ribs
Mixed up 30 grams of ProSeal. Riveted a 426-4-4 rivet in the tooling hole in outboard tip rib. Riveted the small plate over the hole in outboard tip rib. Riveted nose brackets to inboard and outboard ribs. Used hand squeezer. Inserted the fuel vent fitting to inboard tip rib. Inserted both fuel pickup tubes to tank cover plates. Inserted Fuel Guardian sensors into each inboard rib. Placed Proseal on each shoulder of sensors and fittings and then tightened all nuts. Prosealed over everything. Prosealed over nutplates on tank cover and inboard ribs.
