Brief Description: Rivet Flap Brace and Aileron Hinge Bracket
Drilled out half of flap brace hinge line rivets & rivets along rear spar in order to pull flap brace away from aileron hinge bracket. Riveted rib W-425 to rear spar & bottom skin w/rivet gun. Riveted aileron hinge bracket to rear spar w/rivet gun. Had to drill out one rivet. Had to use S-shaped long riveting set to rivet bracket on side of flap brace. Once again riveted flap brace hinge line w/pneumatic squeezer. Riveted almost all of flap brace to rear spar w/pneumatic squeezer.
Inboard Aileron Hinge Bracket & Flap Brace in Place
