Brief Description: NavAid Bellcrank/Aileron Movement
Took NavAid rod off bellcrank & servo. Drilled rod & rod insert together & rlveted together. Cleaned & primed rod. Touched up areas of bellcrank. Reattached rod & bellcrank. Measured aileron movement w/NavAid rod attached. Range is 28° up & 18° down & within limlts. Took left wing ribs home so that centerlines can be drawn on them.
