Dave bent hinge pin end by heatinq it w/welder's torch. Checked total movement of aileron. Found up limit to be just about 30° degrees, down limit to be just about 18° degrees. Movement is within limits, but found NavAid rod bearing attached to bellcrank was bent. Need to order new one.
