Removed A-607 right inboard aileron bracket in order to replace it because of incorrectly positioned hole for aileron hinge bracket. Placed 1" board under bracket. Drilled matching holes through bracket & wood using drill press. Clamped new bracket to wood piece & drilled holes in bracket for attaching to aileron spar. Used reamer through holes in bracket, spar & rib.
