Baker's RV-6
Date:  1-2-2007
Brief Description:  Fuel Tank Anti-Rotation Brackets/Quantity Tabs
Used drill press & Unibit to enlarge holes to 9/16" in fuel tank anti-rotation brackets, per Van's SB. Bent the ends of two 4" X 3/4'' pieces for insertion in fuel tank. These will serve as fuel quantity tabs & be riveted to tank cap ring. Also drilled a hole halfway up as a secondary indicator.
