Brief Description: Right Rear Spar/Left Flap Brace
Drilled #30 hole in center of Right Rear Spar & rib. Pop-riveted LP4-3 in that hole. Found that Right Rear Spar is missing at least 3 solid rivets & LP4-3 in 2nd rib. Also need to rivet 3 rivets in inboard flap brace to ribs 3 & 4.
Took left flap off skin/spar. Vacuumed the area. Deburred all holes. Pop-riveted LP4-3 in center hole in inboard rib/rear spar. Found that the 3 outboard holes in flap brace are too close to the edge. Began to drill pilot holes in flap brace. Spaced the 3 inboard holes on the first two ribs & the middle hole @ 1 1/2" spacing.
Need to do same with second rib/rear spar, left wing. -Done -2/21
