Dimpled some holes in left aileron w/pop-rivet puller and dimpling set. Used hand squeezer and rivet gun to rivet -4 rivets on spar angle brackets. Using Keith Woodell's hydraulic press, riveted -6 rivets on spar angle brackets to spars. First two and the 4th rivets went ok. Third and fifth rivets went crooked and have to be drilled out. Turned rivets around in order to use press. Visitors-John Bohashevsky, Gary and Sandy Palinkas
