Using spray can of primer, primed 4 platenuts. Drilled out a few rivets on spar and reinforcement plates due to shop head bent over. Had used smaller pneumatic squeezer on -4 rivets. The flat head on the squeezer is not strong enough to properly squeeze -4 rivets. Reriveted those rivets and then riveted 2 platenuts onto spar and reinforcement plates. Used 4-7 rivets.
