Baker's RV-6
Date:  12-26-1996
Number of Hours:  4.00
Brief Description:  Rudder/Wing Kit Delivery
Took delivery from ABF Freight Co. of wing kit. Did partial inventory. 15' long box contained fuselage longerons and spars. Drilled out 2 bad rivets re 12/20/96. Reriveted and also riveted platenuts onto spar. DWG 7PP upper right corner showed flush riveting platenut to rudder horn only. Instead machine-countersunk holes on reinforcement plate R-606PP and riveted platenuts to entire assembly. Cut out a small amount of Permatex RTV at each spot and attempted to bend trailing edge more. Put hinges on 2 boards to squeeze edge more. Getting close but not there yet.
