Baker's RV-6
Date:  9-12-1996
Number of Hours:  4.50
Brief Description:  Horizontal Stabilizer-Out of Jig!
Using pneumatic squeezer, riveted bottom of left and right HS skins onto rear spar, tip ribs and inboard ribs. Used hand squeezer on rivets next to rear spar flange strips because the pneumatic squeezer was too large. Dave bucked rivets on one side of center forward rib (HS-607) on right side.
Took Horizontal Stabilizer out of jig!
Dave bucked rivets on other side of HS-607 rib. Finished riveting skins to forward portion of tip ribs. Used -3 rivets in forwardmost hole on each side of the tip ribs. Squeezed them using flat-sided vise grips. Using hand squeezer, riveted left inboard forward rib (HS-405) to skin.
