Ran edges of both HS skins through groove in ScotchBrite wheel. Cleaned both forward spars, all ribs and splice angles using lacquer thinner. Then sprayed DuPont 225S acid cleaner on all pieces and washed it off with water. Dried off all pieces using air compressor spray. Primed all pieces.
