Dave Ross installed VA -146 into center hinge bracket & installed bolts connecting HS-411 to spar. Riveted middle hinge brackets to spar. Riveted outer hinge brackets, HS-413, to spar using -4 rivets. (Plans call for -5.)
*Need to tighten belts w/torque wrench. Completed.
