Brief Description: Completed Attaching Elevators to Control System
The elevator hinge bolts were tightened and torqued, then marked with torque seal. The torque tube was bolted to the elevator control tabs. The bolt was torqued and marked with torque seal. The forward torque tube was bolted to the control sticks. This bolt was also torqued and marked with torque seal.
One of the elevator bolts tightened and marked with torque seal
