Brief Description: Attached Elevators to Push-Pull Tube/Movement
Gary Kohler hooked up the elevators to the push-pull tube temporarily. We checked the movement of the control stick fore and aft, as well as in all four corners of movement. I found that the mic button on the left stick hits the right corner of the GPS box and then hits the throttle knob, with the throttle full forward. The stick does not hit the throttle rod with the throttle pulled out a few inches. some of the wiring and Coax interferes slightly with the stick movements, because all of the wiring is currently loose. This will have to be tied up.
Gary and I attempted to run the trim cable thru the left elevator, but we had to remove the elevator in order to pull the cable thru some more.
The left elevator removed after checking stick movement
