Brief Description: Prepared Empennage Fairings for Glassing Tips
The fairings on the right elevator and the right side of the HS were drilled in place. The left elevator fairing needs to be modified to bring it in line with the HS fairing. The insulation inserts in the other fairings had electrical tape applied to them. A strip of tape was applied on the inside of the fairing about 1/4" below the edge. The fairing interiors were sanded. A block of insulation was cut and taped over at each end of each fairing.
