Baker's RV-6
Date:  12-31-2008
Brief Description:  Cleaned up HS rear spar cutouts/riveted HS
I smoothed out the cutouts in the HS rear spar and the F-611E spacer for the elevator horns. I reamed out the lower bolt holes in the HS forward spar and the F-691 to 3/16''. Used the pneumatic squeezer to finish riveting the left bottom inboard skin of the HS. This had been left open in case I needed access for the trim cable. Swept out the fuselage tail.
Visitors-Joe, Kris Walker
HS bottom skin that was riveted together
Reamed out bolt holes in bottom HS forward spar with F-611E spacer
Cutouts in F-611E spacer to set the down angle of the elevators
