Brief Description: Drilled Trim Tab Apart and Drilled Hinge in Place
Drilled out the top rivets on trim tab because I forgot to install the hinge. Unwrapped the left elevator and positioned the piano hinge under the rivet line. Clamped the hinge to the elevator and drilled the hinge in place.
