Baker's RV-6
Date:  11-13-1996
Number of Hours:  4.00
Brief Description:  Vertical Stabilizer Completed/Rudder
Drilled out and reriveted rivets. Also drilled out twelve others whose machine heads were slightly bent. Wrapped up vertical stab. Complete!
Started on rudder. Clecoed R-602 spar to rudder skin. Using #41 bit, drilled final holes in skin and spar. Deburred all holes. Scotchbrited spar. Used Scotchbrite wheel on stiffeners.
