Baker's RV-6
RV-6
Horizontal Stabilizer
Found attach holes thru left HS-608 to be off-center. Drilled holes thru HS-404's. Laid skin back on right side to line 404 up. Made two shims to go between right HS-606 tip rib and forward spar. (Ended up not using shims.) Visitor-John Knopp
RV-6 Home
5540
544
Control Systems
Cowling
164
199
666
124
570
Flight Training
1225
Inspection
Instrument Panel
142
227
256
Shop Construction
Systems
Weighing
1334
Wiring
126
216
