Brief Description: Riveted Data Plate/Applied Experimental Sticker
The corner holes in the data plate were enlarged with a #30 bit. The date plate was positioned on the left side of the fuselage and drilled in place. Steel pull rivets were used to rivet the data plate to the fuselage.
The Experimental sticker was put on the top half of the baggage cover.
