Brief Description: Enlarged Control Stick Openings in Seat Pans
The openings in the forward seat pans were enlarged per the templates. The cut-off disc in the Dremel was used, along with files and the die grinder with the Scotchbrite wheel. The hole in the left pan was not positioned properly, and it needs to be moved 1/4'' to the left.
