Brief Description: Pulled Fuel Level Sensor Wires from Under Panel
The Fuel Guardian Fuel Level Sensor wires had been tucked among other wires under the panel. I found them and pulled them down.
Since the Low Fuel Warning lights are wired opposite to the tanks, my plan is to cut the sensor wires, crimp Molex pins on them and plug them into a Molex plug. This will allow the sensor wires to be run thru the proper lights for the tanks.
