Brief Description: All Cockpit Fuel Lines Installed
The fuel line from the fuel selector valve to the fuel pump was installed and the fittings tightened at each end. The fuel lines from the tanks were installed and tightened on the fuel selector valve. The fuel selector housing now might cause a problem allowing the seat floor pans to be installed.
One possible solution is to cut off the aft end of the fuel top cover and install a hinge. This would allow the seat floor pans to be installed and then the fuel top cover could be screwed in place on top of the pans.
